WTB MSP Turn signal wires for the headlights closest to the fenders!
M2P503
2003 Mazda Protege5
Hello Every one,
I need to buy the MSP turn signal wires that are off of the Headlights that are closest to the fenders. There the ones that plug right into the Headlight that are closest to the fender. Let me know what you have and how much you want for them. I really need these because i just did a MSP Headlight conversion on my P5 and i have no turn signal wires at all by the fenders! SOS! Please help ASAP ! Thanks!
those are not turn signals, they are side running lights. the side lights in the headlight housing are not needed on a protege5, as they are redundant to the bumper side lights on the protege5. the only turn signals are the inner lights, and are the same between the sedan and the protege5.
Ok thanks for letting me know that man . Well i still do need the side lights on my P5 because i just did a MSP protege headlight conversion and it just looks bad with out the side lights especially at night time personally i dont mind having an extra pair of Side lights lit up so if you know of anybody who has Side wiring harness for the headlights please let me know. Thanks
the harness for those side lights is integrated into the headlight harness, so you won't be able to get just the side light harness. if you want to add lights to the headlight markers, the socket part number is B25D-51-0H8. you can get them for about $12 each. you will just have to rig up some wiring to them. (tap off the bumper lights) alternately, you could try to find a 2001+ sedan at a junk yard and grab the socket and pig-tail.
Oh ok so the side marker lights are connected to the headlight harness itself if that's so and your saying that you cant get them because there integrated into each other then how do they sell them separately like your saying?. I see what you mean. I don't want to add lights although at this point since i did the conversion i still have no High beam lights and that is the most complicated part. Do i need a Relay switch to get my high beams to work? If i do find them ill just splice them into one another.
