cleaned the shell... and just about done with the engine rebuild.. just timing belt components, oil pan and new alternator to install then its ready to be dropped into the car!
Tonight I test fitted a set of front 2 piston 13 inch terminator cobra, that's right cobra brakes on the car. It clears. Would need a custom bracket and a small spaced for piece of mind. Here's the pics.
Rotor comparison
Rotor without caliper
With caliper held into place.
May persue this route at a later date.
I dont' think you need to tap the oil pan for an oil pressure sensor. Im pretty sure you can just screw one of these inline with your oil filter.
Where can I get a conector like that for the oil presure gauge set up.. auto zone ....? And with all 3 gauges it seems everyone is saying to have a power switch for them , so conect should I conect them to a toggle swich..? Cuz I have one in my car all wired and mounted already and don't really need it for what i have it for lol
Should I also have another power sorce when I hook up the gauges as well... Like a compassitor or somthing ....
no cap needed, it's not a high power stereo system. Just some inline fuses on the power wires. Your gauges should have directions for what size fuses to use. I've never had a seperate switch for any guages etc. just tap into an acc line and they'll come on with everything else like the radio and the fuses will be there incase anything goes wrong.
NOt sure about the gauges you have because I haven't used prosport but the wideband has 4 wires I believe. white, brown (or blue?), black and red. I haven't looked at the wires in a while. The white and brown are for data logging and I think you just have the factory ecu so don't worry about those. Your black is ground so look for a good grounding source. I beleive there is one near the in cabin fuse area. The Red is your power wire. This one you ned the in-line fuse for and tapp in to the acc line.
Like I said I haven't done it in a while and I'm going all by memory so someone please correct me if I'm wrong
theres more in the oil pan its like sifting for gold in a river lol... the windage tray is a war zone.. like the incredible hulk was living inside and hulk smashed his way out
replaced fuse and was working fine for about a day now the fuse is blown again(gauge cluster)
