But I care.. And that's why I'm building you all harnesses!Sucks to say, but Mazda could care less about how cleanly designed the wiring is under the hood. smh.
Maybe he just hasn't shown his hood scoop? Please let it be a hood scoop.
Neither does any other manufacturer. They set it up to be assembled as quickly as possible. Same reason on the proteges you have to pull 1 of the rear calipers to get the lower strut bolts out. The struts go on in assembly before the brakes, so they don't care that it adds time and effort to a simple strut replacement so long as everything goes together quickly. If they'd just flipped the strut bolts around there wouldn't be a problem, but that wasn't how they did it.
From another thread. Hope you don't mind me posting the pic, mate.
I believe he means, if you're using a ratchet. cuz if you use a wrench, you're good.Huh? I've never had to remove a caliper to get my rear struts out ...
ahh yes, that's the same for subarus..Nope. From the factory, I think it's on the passenger side rear, the bolts are the "wrong" way in. Even with a ratchet, the caliper and (it's been a couple years since I've done it) IIRC the caliper bracket interfere with at least 1 of the bolts sliding out. The fix is to attach the caliper then re-insert the bolts from the other side. It's been that way on every bone stock Protege I've worked on, including my own. There was always that 1 rear corner that was "wrong".
Where is your air box actually getting air from?
It don't look like it's going to get no air.
or maybe it's coming up from below?.....
Yeah this definitely answers that. Kinda figured someone wouldnt spend the time to put that airbox and the iat sensor and everything and not think about the air intake at some point.. functional scoop is nice![]()
^Oooo, big potential!
