The part has been released http://www.corksport.com/corksport-power-series-downpipe-mazdaspeed-protege.html
Is it possible to remove the downpipe without taking off the manifold and turbo? I've spent some time looking at it, and 4 of the 5 bolts are definitely doable, but not sure about the 5th. It's tucked back there, and not sure what kind of wrench could reach it and have any sort of leverage on it.
I am sure it is much easier with it out and since I've had it out twice, it isn't that hard. But the reason I asked, is I have been battling my manifold bolts (now studs) for supremacy for almost as long as I've had the car. They just don't want to stay in, and now they are all threadlocked. The problem is, if I take the studs out, they will not want to go back in because of the dried threadlock. One hole is already half stripped due to my stupidity, so I'd like to avoid stripping anymore.
I've been waiting for this for so long, I may just buy it to hang it on the wall, along with my worthless SLS mid pipe.
*Edit* Good isntructions, clearly show that it must definitely all come down. I wonder if using a tap would clean out the holes on the head good enough to get the studs back in without major drama.
Is there a Mazdas24/7 coupon code? How about for loyal customers that waited two years for you to start making this again?
I used most of our old instructions for this as we no longer have a stock car to build off of. I had one of the first downpipes on my car (two piece design). I was able to just unbolt the AC compressor and remove the bracket and was able to get to all of the bolts. I was not sure if that was going to be the case with a factory downpipe. I did a lot of looking around and everyone was saying that you have to remove everything to get it out. I also went with it taking it all the way out just because we ship it now with Allen head bolts because the welds have to be so tight to the edge since there is not a lot of room between the bolt holes and the size of piping to clear studs with nuts on them.
Would it be possible to get the stock downpipe out by taking the AC compressor out?
Gb ?
