the Stance Thread v2.0
Back in November,
His stance has always been on point but I still effing love that camo fender. I don't know why I do so much. But I freakin dig it so hard.
If it is going to hit the strut camber will only make things worse. Don't rear link kits help fit wider rear wheels on proteges?
yeah i figured it would not. wanted to make sure with the experts on here lol
+1 and the link kit does not help with inside clearance, as it pulls the entire strut in. It only helps with fender clearance. The K-sport rear camber plays may help with inside clearance it looks like, though.
what circuit said - link kit will allow for more outer clearance, rear camber plates will help with inner clearence. if the link kit is set to min length you will need to dial out the positive camber. this can be done by slotting, camber plates, or if hard up, bolts.
that said with all that 35 is going to be tight
