my car has a short shifter from previous owner and its so short i practically have to stick my hand in the transmission to change gears...I dont likey it.
Hey I've looked on the forum and haven't found anything helpful or recent on how to install a short shifter on the protege5, id really appreciate any help thanks!!!
which one is it? If it's TWM or Kartboy, i'll buy it from you. or trade you for one that I have which is identical to the B&Mmy car has a short shifter from previous owner and its so short i practically have to stick my hand in the transmission to change gears...I dont likey it.
TWM is hands down the best short shifter for this car both in quality and design. the only other one i might consider is the b&m ss.
Does anyone have the TWM shifter? I was thinking about this one once I get the pennies together for it...
I do and i installed it myself and i love the Way it shifts i just wish that it was a couple inches shorter just like the same size as the Mazda Miata ones but i don't think that they make it. Check out my Thread 3 pages below here i gave a VERY VERY DETAILED DESCRIPTION OF HOW TO INSTALL IT. =-)
How much shorter would you say it is compared to stock shifter height?
Thinking about getting a TWM short shifter but I'm not really into their shift knobs...I'm guessing because most of them are weighted shift knobs they stick with the metal.
I want to keep it as short as possible and I'd prefer the stitched leather types or carbons over the metal. Maybe some OEM Mazdaspeed that will work?
From everyone's experience does a weighted shift knob make a big difference over a regular shift knob on a short shifter?
It doesn't matter whether you have a waited Shifty Knob or a regular shift Knob it will not affect your shifting if anything with a weighted Shift knob you will shift faster. Oh and if your Stock Shifter is squeaking a bit i would pull the center Counsel cover off and try and put some more bearing grease around the Ball shaft you'll see 2 white Couplings they usually Dry out after the years so you might want to make sure that there is enough grease in there. Also i would replace the stock bushings with Polyurethane Bushings. You cant use the Stock Shifter Boot with the TWM Short Shifter it would be way to big and it will look really stupid! Just Buy the TWM Black leather BOOT Skirt with Gray Stitching that one looks the best!
Is there anyone else who has a TWM short shifter with a different type of shift knob they would recommend? I'd love to see what they look like.
My stock shifter is squeaking a bit (bushings?bearings?) while shifting and there seems to be a more play then before.
On purchase of the TWM short shifter do you recommend also buying the Polyurethane Bushings and the Shift Boot?
Is the OEM shift boot too big and sloppy after installing the short shifter or can it be modified?
Thanks guys... any advice would be greatly appreciated.
Cheers!
Kerok.
Absolutely bro your welcome The Poly Bushings and shift Boot are worth it you wont be disapointedthanks for the reply! I'll be sure to add the poly bushings and shift boot to my order. I'll grease it up in the meantime.
