Sweet thanks man. Yeah I've had it on for years and now its starting to have a bunch of issues.
ill snap a pic tomorrow. its dark out cause i got out late and i dont have the battery hooked up in the car for light.
haha yea i do. if blowing things up scared me i wouldnt be into building cars through either. i am confident i can hit 300whp and still daily it. you'll see.
idk, i would guestimate around 250whp thats tuned on meth at 14psi stock turbo, been running that for a while. thats just butt dyno and based off of cars i can hang with or beat...
Is it a 1.8L? If so, that probably makes a difference.
3SGTE w/gt28rs on 18psi. Fast ******* car. Bolt-ons, built motor. Just takes forever to spool. Also, I said Mr. Two. Not to be confused with the girls version they came out with later, and appropriately named, the Mrs, lol.
For reference I get full boost by 3k rpm, so that's what I am judging his by. If it don't fully spool by 3k, not worth my time.
but your turbo is a tiny lil snail that takes nothing to spool. n i doubt your running higher then 10psi. psi changes your spool so does the way ur setup is done.
http://onlinemazdaparts.com/parts/2...DA&model=PROTEGE5&submodel=&vehicleid=1416833Where is this so called link, the website in quote doesn't have them listed
i run 14psi, and probably have been since before you owned your protege.
Ugh, unless you have every bolt-on, I'm gonna say no to the 250whp. Put it on a dyno if you want numbers, otherwise your just bench racing.
take your UGH and shove it. thats why used the word "guestimate" and Based on cars i hang with. everyone knows thats what dyno's are for.
also, there is a member on here making 260whp 14psi on meth stock turbo...
I run 14psi, and probably have been since before you owned your Protege.
