My buddy has a friend that does AC...
Please don't say "Mark". (hand)
LOL Negative, this person has an actual auto shop
No, the basic test I had him perform narrows it down to both a pressure switch failure or low system pressure (refrigerant level). Pressure switches rarely fail. My money is on low refrigerant.Thats good. At least you dont have a leak but you will still have to evac all the refrigerant and then replace the switch and do a full recharge.
The afc is working because once I reset the ecu is goes back to my tune, no way the stock ecu would give me 12 under wot without the afc. it also shouldn't come on before 1 psi, which is how I set it. As anyone have a ssafc go bad? Its been on the car for like 4 years now..
How could it be sucking in metered air?Fixed my lean issue I think.... I unplugged the egr. Hasn't run lean since. I guess since I have it sucking in fresh air, it was sucking in in metered air. So I'm pretty sure I fixed it. Walboro should be here and going in tonight
