Awesome turnout. We went for the early session and it was packed.
That's good to hear. It is good to see so much support from your friends and family for this.
ABS is overratedI'm not sick but I have a migraine headache, so that is awesome.
I'm thinking about installing a CP-e triple gauge pod in my Speed3. Ideally I'd like boost, oil pressure, and air/fuel ratio. From my first bit of research it doesn't look like this is going to be the easiest thing to install. It sounds like the air/fuel needs a new wideband sender welded before the 1st cat, and the the oil pressure could potentially be spliced into the existing sender. Anyone have any experience, thoughts, comments, on doing any of this?
Hmm...not too excited about the sandwich plate/conversion kit. What gauges did you have (brand/type of gauge)?
That doesn't look too bad. The sandwich plate would have a fitting for oil pressure and temp?
Anyone else get some Yuengling on draft today?!
