- MazdaSpeed 3
Just purchased them and will have pics posted the day I get them, cause you better believe I am installing them once they get here
Looks good, how do they ride and handle compared to stock?...do you think they are bouncy on the freeway??
Just purchased them and will have pics posted the day I get them, cause you better believe I am installing them once they get here![]()
I'm enjoying mine too...
The springs should not "settle" over time. They are made from a high grade steel and should not go much more than a .25in lower than you are right now over the life of the springs. Cheap springs on the other hand may settle witch just means they have lost some tension.
We used a few different types of springs before going with these. I installed and reinstalled springs on our car countless times. I ran over many speed bumps at speeds I should not have to make sure we got the best ride we could without going overly stiff or to soft.
Well I am def with all your products so far, keep comin out with products and ill keep a CorkSports build...
