Steedspeed with ext wastegate
Here are some new pictures:
More :
2 more :
In a moment, took the car out for a spin. What a difference, the turbo spools up much faster. The afr's are good, I just have to drive home and watch the PSI .
Car is running fine. No problems. The turbo spools up alot earlier and the afr's are still online.
I have to change that. That HP fiqure was when a lot more items were on the car. For the EWG, the boost builds faster and holds constant. Cost wise it is more expensive. And yes I would still do the external WG.
When I had the Thunder we used the spot where the o2 sensor bong was to install the WG. To keep it simple I just kept the sensor in the same location.
That is correct, very close for the WG pipe. I might change it. I found a kit on ebay that has a flex pipe and flanges. I also found I have a small exhaust leak. I will fix that next week. But I am having too much fun with the car.
well that's good that you are having fun with mine needs some TLC right now broken down pipe and shingles blew off the house and scratched the whole side of my car :(
Found a small exhaust leak in one of the flanges. No problem will be fixed on Thru.
Exhaust fixed, now saving some money to go with either Haltech platinum500 or Megasquirt. Found a dealer here in Ft laud can get the 500 with custom harness for $800.(not installed). I going to check the a Megasquirt dealer and see what his price is.
damn thats not a bad price man
