and my point is that its ******* retarded. You'll need new tires every 1500 miles, not to mention your wheel bearings will probably give out pretty quick from the added load of the low offset and the ridiculous amounts of camber.
and even then it probably wont even look good.
Well said phen... too bad nobody listens:Yeah... but different strokes for different folks. Just understand and accept that others have different ideas of what looks good and is awesome to do to the car, and roll with it. It may not be your thing, but they're happy. You do your thing, and you're happy. It's a much friendlier environment then.
Is it possible, of course... Is it probable, not likely... Is it retarded, debatable...
and here I thought these were all requirements to qualify as "aggressive"! Live and learn!and my point is that its ******* retarded. You'll need new tires every 1500 miles, not to mention your wheel bearings will probably give out pretty quick from the added load of the low offset and the ridiculous amounts of camber.
and now i see the part in his sig about a complete 2003.5 MSP areo kit...
now his sig also say "work emotion 11r 17x8 +35, ET's not tooo high
I run 235s on 9s with 1.5 degrees of camber. Just don't understand why you guys think you need crazy camber and small tires to run 9s
Most likely going to order a set of 15mm bolt-on spacers for the front to have them sit equal to the fenders like the rears.
