- 2003.5 Laser Blue MSP
Marko's MSP
--Background--
I bought the car back in 2005 with 25k on it, and for a good deal at the time. I was always a fan of the MSP form the day it came out and always knew I would own one. I couldn't be happier that I bought it and still have it today. Its different and unique in more ways than I ever thought imaginable, and that's why I like it.
--The Goal--
The MSP build is focused on it being a fun/quick track car, but with the ability to still be street driven if I want. I don't really care much about straight line speed and max power, but rather a very well balanced car.
--Current Engine Mods--
-Custom Intake
-Perrin FMIC
-Greddy Type S BOV
-Stock Intake Manifold Ported and VICS/VTCS Removed
-Garrett GTX2867 Turbo
-Tial MVS Wastegate- water cooled
-SteedSpeed T3 Twin Scroll Exhaust Manifold
-Custom downpipe
-Custom 3" S-Pipe back exhaust w/ Vibrant race muffler
-Jay's Racing Fuel Rail
-Seimens 550cc Injectors
-Walbro 255lph Pump
-Aeromotive Fuel Press Regulator
-Microtech LT10 EMS
-J&S Safeguard with Bosch Knock Sensor
-Integral Performance 268/268 Cams
-Kasmankk Adjustable Cam gears
-Focus Adjustable Cam gears
-AWR Radiator with Fan Shroud including 12" Spal fans x2
-Samco Coolant Hoses
-Stant Lower Temp T-stat
-Weapon R Coolant Tank
-Doc B Racing Oil Pump
-Doc B Racing Oil Pan
-Doc B Racing External Oil Pressure System w/ Petterson Oil Regulator
--Built Block--
- Pauter Rods
- Arias 8.5:1 .20 Pistons
-ARP Head and Main studs
--Speed Circuit Built Stg 2 Head
- Ported and Polished
- Knife Edged Intake and Exhaust ports
- 3 Angle Valve Job
-Supertech Valve Springs and Retainers
-Signature Custom PVC Eliminator Kit w/ dual catch cans.
--Current Drivetrain Mods--
-OEM Differential- Welded
-Spec Stage 2+ Clutch
-Fidanza Flywheel
-Neo Trans Fluid
-AWR Front and Rear Motor Mounts
-AWR Driver & Passanger MM Inserts
-Kartboy Short Shifter
-Kartboy Shifter Bushings
-Kartboy Exhaust hangers
-Corksport Shifter Bushings
-Corksport 3rd Link Shifter Bushings
-Corksport SS Clutch Line
-Stoptech Slotted Rotors
-Hawk HPS Brake Pads
-Goodridge SS Brake Lines
-H&R 15mm Wheel Spacers
--Current Suspension Mods--
-AWR Coilovers w/Bilstein Shocks
-AWR Front Camber Plates
-AWR Rear Strut Mounts
-AWR Adjustable Endlinks
-AAC Adjustable Rear Link Kit
-GT-Spec Trunk Cage
-GT-Spec Lower Tie Brace
-GT-Spec Lower 4 Point Brace
-Corksport Front Strut Bar
-Pedders Front Control Arm Bushings
-Pedders Trailing Arm Bushings
--Current Misc--
-Volk Racing Wheels TE37 17x7.5 +40
-Custom Power Steering cooler
-Dave B Gauge Rings
-Black Face KPH cluster
-Greddy Profec II- EBC
-Apexi Turbo Timer
-Defi Boost,EGT, Water Temp, Oil Temp & Oil Press Gauges
-J&S Safeguard Knock/Retard Gauge
-AEM Wideband
-DG CF Arm Rest Cover
-XC CF Reverse Cowl Hood
-DG Front Lip
--Future Plans--
-Custom Fiberglass Front Splitter and Rear Diffusers
-AAC Front Control Arms or Custom
-Roll Center Kit
-Sparco Seats w/ wedge brackets
-OMP 4 point Harness
-Stoptech BBK
-Oil Cooler
-Trans Oil Cooler
-M-Factory LSD
-PAR Straight Cut Gear-set 1-4
-Better Standalone- AEM Infinity
-Plus other stuff I cant think of now.
