Minerva motorwerkz mount..part review
07ms3obrien
07 MazdaSpeed3...06 Mitsubishi Evolution 9 SE
Well i seen the thread on here about someone putting a minerva PMM in the 2010 speed. Alot of people jumped to conclusions about them being Medieval, which happens alot on this forum (people jumping to conclusions) but, i went ahead and emailed them anyways. We swapped acouple emails and after talking to them i gained their trust to spend only $99 on a mount. what the hell they have a ebay store and i can always despute the purchase. Minerva just got the design from medieval.
Anyways i got the mount in about 3 days after i purchased it on ebay. (yes i was alittle nervous) My wife then had our daughter so it delayed the install alittle. i installed it two days ago and did some daily driving to work, some launches and also a track day where i made 6 passes.
I cant really go into to much detail yet because its only been 2days so ill keep updated this but for now this company is trustworthy, very quick responses and of coarse great pricing!
im going to attach some pictures.
install was easy
1.unbolt coolant tank and just bend it back. (something under engine to support it. to be safe)
2. unbolt the mount and just take it out.
3. take out the studs on the block (for this mount you have to remove them just to drop new mount in.
4. remove the ground wire then just relocate it up on the shield. drop the mount in, put the bolts that go to the frame first then screw studs back in. (i used anti seeze for all bolts)
5. tighten all bolts then bolt the tank back on and your done lol
sorry its a quick review but i know ill get blasted with hate and other s*** lol but i took a chance with this company and ILL BACK THEM %100..
Aso i only have a CPE CAI and a PG TIP. ran a 14.1@104 with the mount went 13.8@ 102.8, temp was different by 8 degrees.
Start the questions, also if you think i work from them or w.e ill give you my contact info im about 1500miles away.
Yea a lot of people say that..well only afew but I received my mount and its good so far..well see with the others.
I believe the guy had a good product and the owners or someone working there started to rip people off and screwed it for the fabricator. And now he's just trying to get his design back out there and I'm here to help
