Funkalicious21's Protege5 Build/Progress Thread~!
Haha very true about blowing smoke out near a cop, oink oink. I'm boosting soon too and I'm looking at my options for an exahust as well. Will going 3" in the midpipe sacrifice low end but gain top end?
Going 3" midpipe should probably help low and top. The larger piping allows more air flow and less restriction compared to the stock pipe.
i think its fun to blow smoke by cops, well if you can do so without speeding. its a fun time.
Hahah...that would be nice, but I live in California where that can lead to things that aren't so fun =P.
Engine Modifications: (2.0L MSP Motor Swap 87k)
-12” Slim Fans (2)
-505 Custom Intake Manifold
-Aeromotive Fuel Pressure Regulator
-ARP Exhaust Manifold Studs/Nuts
-ATX to MTX Engine Harness Swap
-ATP Wastegate
-AWR Front Motor Mount inserts
-AWR Passenger Side Motor Mount inserts
-AWR Rear Motor Mount inserts
-Forge BOV / HKS SSQV V2 BOV
-Fuel Pressure Regulator
-Garret GT2554R
-Injen Cai
-MAM Turbo Manifold
-MAM Straight Water Neck
-Mazdaspeed Protg Oil Cooler
-Mazdaspeed Protg Bypass Valve
-Mishimoto Aluminum Radiator
-NGK Spark Plus Wires
-Optima Redtop 35
-Perrin Fuel Rail
-Stainless Steel Oil Line
-Turbo Life FMIC
-Vibrant Silver Vacuum Block
-WRX 440cc Injectors
Fuel Management Modifications:
-Mazdaspeed Protg ECU
-Split Second Fuel Time Controller
Transmission/Drive train/Shifter Modifications: (ATX to MTX Swap)
-Mazdaspeed Protg LSD transmission Swap
-Mazdaspeed Protg Flywheel
-Mazdaspeed Protg Axles
-Mazdaspeed Protg Manual Shift Linkage Swap
-Mazdaspeed Protg Light Weight Flywheel
-TWM Short Shifter
-TWM Shift Link Bushings
Exhaust Modifications:
-Calleyway J Pipe
-Calleyway S Pipe
-Corksport Hangers
-Pope’s 3” Down Pipe
-Thermal R&D 3” Exhaust Cat-Back
Brake Modifications:
-Drilled/Slotted Rotors Front
-Drilled/Slotted Rear Rotors
-Front M6 06-07 big brakes
-SS Brake Lines
Suspension/Handling Modifications:
-AWR Rear MSP Endlinks
-BC Racing Coilovers (BR Series)
-BC Extended Dampening Cables
-Eibach SPC Camber Bolts
-KMR Front Tie Bar
-KMR 4 Point Ladder Brace
-KMR Rear V Brace
-MX-6 Rear Sway Bar for
-N2ka’s Custom Rear Link Kit
-Racing Beat 20mm Rear Sway
-Racing Beat Front 24mm sway
Tires/Rim Modifications:
-Blox Extended Lugs
-Blox Extended Studs
-Federal ss595 205/40/17 (2 Inch Stretch)
-H&R 25mm Spacers Rear
-Hub Centric Rings
-Nankang NS-1 195/40/17
-Rs5 Tenzo 17x7 +42
-Tuner Lungs
-XXR 962 17x9 +35 front
-XXR 962 17x9 +10 Rear
Appearance Modifications:
Exterior:
-5% Tint Windows
-Alocade Eyelids
-Custom Retro Fitted Headlights Projectors
-DGM Carbon Fiber Air Ram Hood
-DGM Urethane Front Lip
-ForceFed Single Gauge Steering Column Pod
-Fatlace License Plate Frame
-iSport Carbon Fiber Rear Spoiler Extension Lip
-Latitude Rain-X Wipers
-LED License Plate Light Bulbs
-Mazda6 Rear Wiper Swap
-Shorty Atenna
-Tenon HID Headlight Kit 6K
-Tenon HID Fog Light Kit 3K
Engine Appearance:
-Aerometer Oil Pressure Gauge
-Air Diversion Plate
-DGM Engine Cover
-DGM Carbon Fiber Oil Cap Cover
-DGM Valve Cover Brackets
-Engine Semi Wire Tuck
-ForceFed Wrinkled Black Valve Cover
-Stock Red Strut Bar
Interior:
-Autometer Boost Guage
-Autometer Wideband
-Autometer Oil Pressure
-Carbon Fiber Shift Boot
-Carbon Fiber Trimmed Ash Tray
-DG Carbon Fiber Radio Cover
-Dave-B Cluster Rings
-HKS Turbo Timer
-Mazdaspeed Protg Shift Knob
-Mazdaspeed Protg Gauge Cluster
-Mazdaspeed Protg Pedals (Clutch, Brakes, and Gas)
-Mazdaspeed Protg Floor Mats
-Mazdaspeed Protg Seats Front/Rear
-Nardi Miata 99-05 Steering Wheel
-Protege5 EL Door Sills
-Protege5 Cargo Net
-Sparco Pedal Covers
Audio/Video:
-Inifnity Basslink Sub/Amp
-Infinity Kappa 6x9 Component Speakers
-Infinity Kappa 6.5 Component Speakers
-Rockford Fosgate P400-4
-Rockford Speaker Cables (sub only)
-Rockford Subwoofer Interconnect RCA
Misc:
-Clarion 2-Way Alarm
-Mobile 1 Fully Synthetic Motor Oil
-Royal Purple 10W30 (now using)
-MOCC Forum Decal
-Redline MT-90 Manual Transmission Fluid
-Team Pro5 Decal
-Wix Oil Filter
Future Mods:
-Dual Pod Gauge Cluster
-Oil Relocation
-Customer 3” Mid-Pipe
My new addition to the build! I plan to get everything installed in the near future. =) Really glad I got my hands on one of these. It'll open a lot more =D. Thanks Darrel for everything brotha!
hi i was looking at the stance thread and love ur car looks amazing and i was wondering how much camber u run with the 17x9 with the +35 offset cause i wanted to get some wheels that wide
realy dam how much of a stretch though like 205/40 cause thats the stretch i wanted to do and how much camber would i get in the back ??
I have lots of updates guys! I have lots of pictures Of the progress I made today. Definitely looking forward to eating from all the people who still follow my thread.
As for the 17x9. You can easily fit them in front, just stretch the tires. No camber needed. As for the rear, just needs slight roll to make them it well. If you'd like to have my setup in the rear it's a -7 camber and it'll need some work to get it like that. Not fun but worth it. I can help you out if you decide to do it.
My Summer just started and so has the start of new beginning for my baby!
I have tons of stuff that have been laying around in my garage and I've been dying to install!
I took off the bumper because im sitting too damn low for me slip a jack under. I used two low profile jacks to get me off the ground.
Started to remove the radiator to make room for the 3" Pope down pipe.
Taking off the whole turbo assembly to replace it with my MAM tubular manifold and also something secretly planned that i'll show you guys later when it arrives =)
Trying to decided what was the best way attack this obstacle of taking off the S-pipe from the turbo. One of the biggest b@$!# to get off!
As i was taking out the turbo i ended up ripping/tearing up the oil line hose for the turbo. =/ Gotta get a new one now.
Picture of the whole front of the motor gone.
