Maxx Mazda's 2011 Build Thread
How you like that Rotella T ? is it used on P5 ?
Looks like I can pull it off to DIY forging the engine, doing great job with details and pics ...
Rotella is a diesel oil, used as a break in oil only. I had it there for piston assembly.
After initial engine break in, I'll be switching to full synthetic. Never run a new engine on synthetic for it's break in.
I just noticed no cutout in your VC for cam timing adjustment? Or was the advance threshhold pretty much established with your last set-up eventhough not as insane :)
Adjustable cam gears are useless with the Integral turbo cams. They're already pinned for 0 overlap and maximum flow.
i just finished reading this and man this is an insane build. this is truly an inspirational build
Gotcha, what brand/weight synthetic oil you'll be using ?
Well, the engine is DONE! Blueprinted and assembled, ready to drop in the car.
Recieved my last valve shims so I could finish it off. Needed a total of 14 shims, at close to $9 each, you do the math...
New shims are nice because the measurement hasn't worn off yet.
New shims installed in the correct locations. This is where my previous meticulous note taking comes in handy in speeding up the re-assembly. Everything was coated liberally with assembly lube.
Cams in, and caps torqued down, we can rotate the cams to the correct position and double check our clearances again. Remember, we're looking for 0.009"-0.0012", aiming for the looser side of spec. All shims checked out within spec!
Completed head. Remember to use silicone sealant on the end caps.
Fresh cam seals were pressed in, and the engine timed. The 626 exhaust cam gear is shown, having only one home pickup, vs. 3 on the stock intake cam gear:
NOTE: The second picture shows the engine timed incorrectly. Bonus points to the person to illustrate why. (Obviously the timing was rectified after taking this pic.)
Don't forget the silicone before installing the valve cover!
And finally...
The Completed Engine:
Both cam and crank position sensors are routed to the same area, so that my new engine bay harness will be very discreet.
That's all for now, have a good long weekend everybody!
arent the I and the E supposed to point at each other, not both E's? thats my guess lol
and maybe its just me, but Ive never had a leak from that last cam cap with no silicone. I know it says it in the manual but i didnt do it for some reason and never had a leak.
Your100% right the Intake and Exhaust marks need to be pointing towards each other
I am all too familiar with the cam gears, it took me a couple days to finally get the timing set right after doing the timing belt.
BOOM! Right on guys.
An interesting find, is that I wanted to see if those cams turned my engine into an interference motor, and they do, in fact. I positioned the cams so that they depressed the valves, and then very slowly rotated the crank until that cylinder hit TDC, and the piston did in fact make contact with the valves. I do NOT want to break a timing belt.
So the silicone goes on the end caps after they are torqued down or before? Any reason you didnt go with a quaife or mfactory lsd?
But if they do touch, isn't bad news ? Bent valve or hole in the piston
Broken valve. Mind you, with these dual valve springs the likelyhood of that happening is slimmer. Alot of stock engines are an interference design, in fact the FS was a bit special in the fact that it wasnt, so this is nothing new. Just something to be aware of now.
Similar Threads and Articles
