Have you tried clearing the CEL and checking to see if they or either of them come back? Sometimes the sensors react to small changes in flow (even with your catted replacement, the 3 inch system all the way back may be making the sensors over-react.
Are you monitoring?
What is your fuel pressure under load?
What is your wastegate doing under load.
What boost levels are you now seeing and are they different than before?
Are you seeing any boost creep?
"Modded" in your sig does not help us sort things out. Mods list, please? Did you change anything else when you installed the catted TBE?
