boost spike and high boost on stock ms6
b20eg6
2006 Mazdaspeed 6
Im having some boost spikes whenever i put my foot down it spikes to 17 for a second then drops to 14 and stays there till i let off. Tried 2 diffrent boist guages both read the saame. Any reason y its spiking and y im running 2 pounds more then i should be? Thx
17 is not bad :).. I spiked to 25.. then again mines got all the boltons besides the top DP piece. You can reset your ecu and drive it around for a few hundread miles then see if it does it.
Mine adjusted itself after awhile I hit 17-18 psi no more spikes above that
Bone stock ms6. I did i tried this a couple times i drive alil over 100 miles aday and gave it a week every time to adapt still nothing. I had a glowshift now a autometer guage. Both reading the same so its not the guages.
mine spikes to 24
check for boost leaks, any loose clamps, any/all hoses, connections, etc. Your waste gate might be mulfunctioning and lagging just enough for a spike. Check oil levels. Check the connectors to BCS.
If your car is completely stock and it behaves differently from what it used to, there is some kind of mechanical issue.
