I hear you guys...I'm working on some pictures. For 2 weekends in a row I've tried to put the motor in but something always comes up, today it was a complication with the half-shaft and knowing how much easier it is to work on it without the confines of the engine bay I called off putting it in.
Since the last update, I finished the mazda6 brake upgrade, sans ebrake. I bled the system and it felt as if the system was very soft on the first push, but every push thereafter would feel great. I ordered a new master cylinder, but it has yet to arrive, hopefully that resolved the soft pedal and to be honest, the rest of the system is new, why not do the master cylinder? Today, it seemed to be an off day. I got the clutch/flywheel/trans bolted together, but when I went to put the halfshaft in, I had a hard time getting the flange to bolt up. It seemed as if the offset was all wrong, like the flange was too thick, however I do know that it bolts up as I tried it prior to the install. I'm having a machine shop take a couple of mm off of the shaft to see if I can't get it to line up.
Things just weren't going well today, I snapped some pics, but over all it was just hurdle after hurdle. I should probably take some time to clean the space, spent too much time looking for parts. As soon as I get the halfshaft back (if it fits) we'll be putting the motor in
, then it's a few weekends getting the engine bay together and doing all of the wiring.
