Oil light flickering!!! WTF, Chuck???
alca0811
06 MS6
Hey peeps, my oil light seems to be flickering when I start the car. It seems to go away whenever I start to drive it more, but this has been going on more and more after I switched to the spin-on oil filter conversion kit with the sandwhich plate for an oil pressure guage. Does anybody know what it might be?? If more info is needed, just let me know.
If it's only when the car is starting, I bet the spin-on filter you are using either doesn't have an anti-drainback valve, or the valve is too weak for this motor. The anti-drainback valve will keep some oil pressure in the system (albeit very little) to prevent oil starvation during startup.
This might not be the issue, but your symptoms make sense to me. Unfortunately, I have no idea what specs you'll be looking for regarding the filter you would need to run.
It's the mazda spin-on filter that comes with the kit from SU
I'd look into whether you have a small leak.
got under the car yesterday, and eventhough everything was tight, there seemed to be a leak from somewhere. I think that I am going to have to look a bit deeper into this. Unfortunately, it won't be until tomorrow. Luckily, the dip-stick is saying that I am good as far as the oil level goes.
I got to stay back there so when you break down I can pull over to help you...
Hope you get it figured out
so I had to fill up the car with around 5 quarts of 5w30 yesterday because the car was almost bone dry. . . eventhough everything was tight as a 12 year old. I know that I have a slight oil leak, just need to dig around and see where.
Oil plug is still there Terry.
ok so you say slight leak yet almost 5qts was gone?
