My Build Progress
ok everyone here is an update. the car started and is running good. ive been exploring the microtech system and its been very simple for me to use. on 10psi and 11.3 AFR car feels Very strong
Lookin good dude! Hope you have some sticky-ass tires!! :)
Just curious what kind of afr's you're able to get at idle with those injectors without them cutting out in hot weather when they are barely spitting fuel?? Also are you using the stock fpr?
If I drop my injection time below around 1.300Ms they basically stop flowing?? 10.5afrs for me at idle with my 750's
If I drop my injection time below around 1.300Ms they basically stop flowing?? 10.5afrs for me at idle with my 750's[/QUOTE
well to be honest the tuner took over the car already but all i know is that the 1000cc's are alot lol. nd i will be bumping the car to 18psi today when i get my new rims (stock evo 9).. they are 17 X 8 so i should be getting some good traction. i hope. if not then i gotta look for a diff set of tires
thanks guys !. im very excited to see how this works. in about a month or soo i will be making a custom intake manifold with ITBs.. ive been drawing out the diagram and it seems like it will be right now all is left is to do some construction lol. Also i have an 80mm throttle body custom made. im excited and im pretty sure you guys are too. i will be saving the cams , intake mani , throttlebody for my next setup . soo i will push as much power as i can with this setup . i will hopefully make over 500 with this
Go and see Mack at Emerald Performance. He has the ITB's with manifold assembly already.
So i know its been awhile since ive posted on here but here are some updates with the car.
Shes running and running amazing i get good gas mileage with the 1000cc injectors and pump. my afrs are around 13.9-14.7 cruising.
im currently street tuned on 15psi no dyno numbers yet but as of right now she moves. im very happy with this turbo and i recommend it 100% !!
WOW!!! im liking this setup you got goin here...
question: as for the tranny, are you sayin that all you really need is pretty much an lsd to save the gears??
subbin for dyno numbers and outcome of future plans
Hey everyone i havent posted on here in a Pretty long time but id like to give everyone an update on the car. Shes been running on 25 psi on the gt30 for a good 6 months making 538whp 492trq . Nd yes all that on a STOCK geared tranny ! . all i have is a quafie lsd . soo now comes the sad part about a week ago i was driving home from work and as i shift into third the car starts shaking and before i know it third gear decided to take a s*** on me -__-. soo we took the tranny appart and ill post the pics of what it looks like. but i broke 3rd gear and damaged my final drive gear so now i need a new one. to cover the gear that i broke i orderd a cpboost 3rd nd 4th gear combo both gears are billet and double synchroed. well ill keep everyone updated on the progress of the car ^__^.
