AutoEuphoria
- '08 CPW Mazdaspeed 3
A few months ago, my engine blew. Threw a rod or something...doesn't matter at this point, it was completely toast. Wasn't covered by warranty, so I ended up paying a LOT of money. Had to sell all of my aftermarket stuff to help offset some of the cost.
Car has a brand new engine right now, and is just as stock now as it was when I brought it home from the dealership.
I have an issue now, though, that I can't seem to figure out. My car wasn't stock for long, so I can't remember if it acted this way when it was. I'm guessing not, but honestly I don't know what to even look for at this point.
If I go WOT in second I sometimes get a slight misfire. This happens much more often in third, fourth, fifth, and sixth (happens at partial throttle in 5th and 6th...I never go WOT in any gear higher than 4th, and that is rare). Always happens under boost, and it seems like it's some kind of fuel cut or boost cut or something...just a series of misfires.
I do not get any CELs, my fuel pressure look fine, my AFR looks fine, no knock, boost temps are low, etc. The ONLY thing I can think of is the shop may have used inferior (or wrong) spark plugs when they installed the engine...that or it's perfectly normal. I'd hate to think any stock car would run this poorly, though, even on bad winter gas.
So, any ideas? Any parameters I should log to help give more insight?
