My LED swap
Swapped all of my interior lights today too, I went with the same ones as OP, man what a difference...the install was a walk in the park....
I was stupid though(hide), I didn't see that CorkSport had the kit for sale, I would have definitely went with that kit if I saw that they had it...I paid $38 for all of my lights(Interior only)
Keep your receipts kids. I've had two SuperBright LED's fail on me. One didn't work period (exchanged), the other flickered after 2 months (can't find my receipt!)
thats a shame, i have had all my SuperBrights (full interior, parking & rear license plate) for nearly a year now.
no problems.
zoomzoom, which location did they burn out @? the parking light ones wouldnt surprise me as they get extremely hot with the headlights on.
My dad and I had our superbrights since january and they are still bright as hell. Interior stays on all the time on both car and we have had zero problems.
The one didn't work period either way I put it in (rear dome). The one that flickered was in the license plate.
I ordered the WLED-WHP9-T's for my parking lamps. I'm assuming this is incorrect?
I assume that has 9 LED's? I don't know if that will fit...
It just looks like I ordered the wrong bulb completely. The factory bulb has the tin housing for the wire clip and this simply looks like a 194 (wedge bulb).
So now looking at the bulb that replaced the one that was flickering is now flickering, on top of that, I can't find my receipt! Not very happy right now!
sounds like you have issues with the car, not the bulb. it's not a coincidence two bulbs failed prematurely in the same way.
if anyone wants LEDs, pm me. I got a bunch that fit our cars, and I'm letting them go cheap.
Funny thing is that the incandescents work fine, as well as the other working LED, didn't flicker in that slot.
So what is the part number from superbrightleds that you would use for the parking lamps?
They are 194's. It's just a matter of how many LED's you can fit on one diode that will still fit into the lens housing, how many that is , I don't know. I know the 'Tower II" bulbs are a squeeze though if that's any help.
Not sure if people have been looking, but all the information should be posted in the first page with regards to parts and numbers. All of mine have been working fine, one bulb went out (bad luck?). As for the parking light, the Tower II is an extreamly tight fit, that needs to be wiggled in lol. I advise caution, and to tape the bulb to the parking light housing with electrical tape so it doesn't fall into the main headlight housing. The Tower III will NOT fit, in case people were wondering.
These are the 194 LED bulbs, how are they supposed to go in the parking lamps when the stock bulbs looks like this?
Hmm... I don't know what those are that you pulled out, but those are not the parking lamps. The stock bulbs are garden-variety 194s.
-Jay
Then the must be the DRL's I'm guessing...
Odd. There are four bulbs in the MS6 headlight array: high beams (H1), low beam (D2S), parking lamps/city lights (194), and turn signals (1157).
Ahh, okay. After a little Googling, I have determined that those are the high beam (H1) bulbs (the only ones I haven't replaced in my MS6 (rolleyes)). You're looking in the correct general area... The parking lights should be right above those high beams.
-Jay
-Jay
You are absolutely correct sir. I had to get down on a knee to see that the driving lamp existed, and then it was a snap to change out. The WLED-WHP9-T worked perfect and looks great too!
