Tiny battery on an otherwise stock looking car?
I guess my goal with this car is a solid 11 second DD with all the comfort it can offer.
-Em
Good luck!
I agree with the traction thing for sure. This was something I wanted to make so we can sell it later. With that being said, the easier the better. We will be making a lot of new parts for the car and this is just the start. Hell, I just picked it up friday. LOL. Next up, I have to get it on a lift and take a look at the exhaust. After that I will tackle the IC pipes and intake along with a few other things. I plan on putting a call into a few different cam manufactures that we use to see what they can come up with as well. I guess my goal with this car is a solid 11 second DD with all the comfort it can offer.
-Em
I spend to hours getting her shiny and spotless. I guess it was worth it cause I got a first place trophy![]()
high idle could be a mistimed cam, fortunately, these are non-interference engines so it won't blow up.
I would also double check for vacuum leaks.
what i do when i time the car, is pull the cyl.1 spark plug and put 2 pretty long 3/8 extensions together into the cyl
then just turn the crank till it comes up, thats TDC, then just slip the belt on and put both cams pointing the line toward each other
obviously thats the quick way to do it, ive done the timing belt 3 times so far, worked perfect each time
