You could always join the military. thats what I did...
I quit my job in june to go back to school full-time
if only it were that easy...
Woah. I did not know that. I guess it has been a while since I've been on this forum thingy.
You likeing it over there? They have'nt tried to kill you yet have they?
going under the car tomorrow, i think i broke my sway bar bracket and that is the cause of my problems. This would be the second time if that's the case.
Dude, just take some advice from the slammed guys and slam yo s*** to the ground. At that point you're so low you might as well disconnect your rsb cus you're so low you don't get no body roll.
Duh.
I did that 3x on the P5. Lube the bushings as much as you can, and do it often.
I was thinking of trying these http://www.jegs.com/i/Prothane/311/19-1168/10002/-1 (style A) the bushings are 25mm if I remember corectly.
Levi got some ones that were meaty as hell, and had a bit of trouble getting the bushing inside the metal bracket. I think he ended up trimming it with a dremel at the bbq.
