CheeseHelmet
For the past couple weeks I've been trying to figure out how I can repair the threads of one of the captive nuts that holds the transaxle motor mount in place (the bolt size is M10x1.25).
Here's the nut in question (red arrow):
Here are the solutions that I've come across so far:
Please share your thoughts/ideas, I'd like to finally get this fixed.
- Tapping the hole to a slightly larger imperial size (like 3/8-16NC)
There's not enough thread left for this to work, I've tested this on the bench (running a 3/8-16NC tap through an M10x1.25 nut) and the resulting threads are very weak.
- Drilling then tapping to M12x1.25 or M12x1.5
Is the captive nut big enough that I can drill a hole for an M12 bolt? I fear that I'll make the hole but then have nothing left to tap. Also, this would require making the bolt hole in the motor mount larger which I'm not too keen on doing.
- Installing a Helicoil
This looks like the best option, mcmaster-carr sells an M10x1.25 helicoil kit for $43 and it looks like I wouldn't have to drill too big of a hole (iirc the diameter of the hole only needs to increase by 0.5mm). Please tell me that the nut is large enough for this option to work ;_;
- Installing a Thread-Sert
I can't find a kit for under $75, that's a lot of money for something that doesn't seem to be much better than a helicoil...
- Drilling a hole in the bottom of the frame and passing a long-ass bolt through
Is this crazy enough to work?
