HELP!! Alternator whine w/ new setup
Hi everyone! I am in desperate need of advice to get rid of alternator whine on my new setup.
Like many others on this forum I was not overwhelmed by the sonic quality of the Bose system on my MS3 GT. I ditched the Bose amp, subwoofer and speakers and replaced all this by
- an Alpine PDX5 amp installed under the passenger seat
- Image Dynamics components for the front doors: one crossover is under the driver seat - where the Bose amp used to sit, the other one is next to the PDX5 under the passenger seat
- an old set of Polk DB570 coaxials for the rear doors (don't really care about the rear doors to begin with, but could use a little filler back there)
- don't have the sub installed yet, but planning on getting a Pioneer Premier shallow mount sub for my trunk.
I reran new speaker wires through the dreaded Molex connectors for all 4 doors using 16awg, and 12awg between the amp and the crossovers.
I ran a 4awg wire from the battery to the amplifier through the grommet behind the glove box, as exposed on this forum (that was great by the way!). The power wire is running on the right side of the car.
The amp is grounded on the cross beam between the center console and the right door, right in front of the passenger seat. There is a threaded hole there - where the Bose subwoofer was attached - so I sanded the painted area down to the bare metal and grounded the amp right there.
I tapped into the Bose plug on the driver side and drove RCA's through the center console to the passenger side to connect to the amp. The RCA's are not close to the battery power wire.
The problem I am having is that, when the engine is running and the amplifier is on (even if the head unit if not on), I am getting a buzzing/humming sound through all 4 speakers.
What I have tried so far:
- If I unplug the RCA's, the buzz is gone (so the amplifier is not the source of the buzzing/humming), so there probably is a ground loop somewhere in the system through the RCA's shield/-
- If I step on the gas pedal, the frequency of the noise goes up, so it is likely alternator whine that I am hearing
- If I plug only one of any of the 4 RCA's, I am getting noise on the corresponding speaker
- I ran a 14awg wire from the head unit chassis to the where the amp is grounded (again, right in front of the passenger seat) to try to kill the ground loop, that didn't make a difference at all. Does that mean that the ground loop is not between the head unit and the amplifier??
- I also removed the fuse for the Bose amp, so the former power wire for the Bose amp is de-energized now
I am running out of ideas... I am starting to think it could be either the FM antenna or the Sirius box that are not grounded properly, or maybe the aux input. I figured that anybody who modified their system likely had a similar issue? It just seems like I have been super careful, but somewhat still created a ground issue by accident.
Any suggestions are welcome! Thanks a lot for reading this!
sounds like you have a decent understanding of what your trying to do.
I would approach this from the RCA side, you are sourcing the HU at the connector under the drivers seat, correct? those are low level inputs, but they are not shielded. how mazda made that work, I have no idea, but it is what it is. from there I would try a temporary, and drastic reroute of the rca cables and test.
I can tell you that the power cable running into that connector that plugs into the bose amp is quite sufficient to run my 1400 watt LSX amp, and since it is the factory wire, they routed it to prevent whine. just sayin.
Man you coulda bought a JL amp and never had this problem in the first place. Not that I have one anymore (and as such I'm using GLI's), but I doubt I'll buy any other brand in the future. Differential-balanced inputs are a beautiful thing. ;)
Here is the funny thing, I had the same problem with the JL 300/4 too, which has isolated inputs. That was mind boggling! I must had been picking up noise on the RCA cables, but from what? No idea. I was using (and still am) a good quality cable, with twisted pair, shield, braid, etc.
Now it's all good though, I couldn't be happier!
Good! Weird about the JL, cause I tapped into the wiring under the driver seat, and out of 5 amps I've used since I got the car, only the two JL Slash ones didn't make any noise without GLI's. My ground runs straight from the amp to the battery (couldn't pass up 4 gauge amp kits for 15 bucks each...), although I did originally use the bose power connections that meicalnissyen was talking about.
