Talked to the service manager today about bringing the car in Tuesday. Told him the problem and that I'd need a loaner because it would take them awhile. He said, "Yeah, we'll get you car. We're used to this." LOL
they pulled the turbo off and found a leak
where are you located?
Found a leak? A leak? Does not make sense. Sounds like the stealer dealer is just making work. I would bet good money that your turbo will, sooner or later, "smoke" again. It goes with almost all make and model turbo cars with high boost, high compression ratio, high crankcase pressure engines.
OK, got her back today. They also found/fixed a coolant leak for me, all under warranty. WHew!
You removed the OEM cats and installed the COBB DP, so that voided the emissions warranty, along with the powertrain warranty.Hi I have a 2008 ms3 with cobb catted dp and forge bypass valve. started smoking back in NOV. when I added the DP. Took it to mazda w/mods it sat for over a week and then the mazda rep declined the repair and then branded my vehicle and voided all future warrenty repairs.. this is against the law the parts did not cause the seals to leak. I filed complaints with the BBB and the FTC. Has the delear done this to anyone else denying the repair? Its a B**** to return it back to stock.
MazdaSpeed3 '07
build date: 03/07
No mods - bone stock
So I have had continuous problems with my car smoking at idle with bluish smoke.
Bought my car in May 07. For about a year it was fine then it started smoking at idle. I took my car to the dealer with about 27k miles on it and they replaced the whole turbo. My invoice says the newer turbo kit was used (L3Y1-13-70ZB). For about year this new turbo was OK. Then I started noticing smoke at idle. I sit in traffic about every day so I am at idle or near idle alot. It got so bad that it would start smoking after only 45 sec at stopped idle after the car warmed up. Last month I took it back to the dealer with about 52k miles on it. The dealer was sort of short with me and told me I better have all my oil change records, which I did. So he recreated the smoking with no problem and talked to mazda central. They told him (I am only relying what he told me they said) that he should switch me from the 5W-30 natural oil to 5W-40 synthetic oil and that may work. They also said they mazda was preparing a bulletin that will be released soon and that may be related to my problem. Well, the oil change worked for about 200 miles and it is now smoking again about as bad as it was 2 months ago - so that fix was short lived.
I am calling again today. I am a bit worried they are just stalling til I hit the 60k mile drivetrain warranty expiration.
Any suggestions WRT to working with the dealer so that I get a fix that works long term?
MazdaSpeed3 '07
build date: 03/07
