Test Drive: BMW M3 GTS
mikeyb
Contributor
01 BMW 325xi Touring
What is it?
The most extreme factory backed iteration of a road going BMW M3 yet the new GTS. The final act for the current M3 prior to the arrival of an entirely new model in early 2012, it is essentially a track car that just happens to be road legal here in the UK, thus the licence plates front and rear.
At 1530kg, it is 75kg lighter than the standard M3 for a start. The weight loss is achieved, in part, by the adoption of titanium rear silencers and 19-inch light alloy wheels. In true racecar practice, the glass rear side windows and rear screen make way for lightweight polycarbonate replacements.
Further reductions come by way of a pared down interior. It has been liberated of just about all of its comfort orientated features, including the front seats which are replaced by one piece carbonfibre jobs with three-point belts.
The M3 GTSs added performance stems from its engine. Its no mildly tweaked version of the fifth-generation M3s naturally aspirated 90-degree 4.0-litre V8. Rather BMWs M division has developed what amounts to a whole new powerplant.
The bore remains at 92mm but the stroke has been extended by 6.8mm to 82mm, resulting in an overall capacity of 4.4-litres. Power tops out at 444bhp 30bhp more than the standard M3, while torque jumps from 295lb ft to 325lb ft and is developed 150rpm earlier at 3750rpm.
Channeling the new cars added reserves is a beefed up version of the M3s optional Getrag-engineered seven-speed M DCT (dual clutch transmission). As is now a feature on all of BMWs M models, theres a power button and toggle switch to alter the characteristics of the engines power delivery in five distinct steps.
Whats it like?
Fire the M3 GTSs new V8 and youre immediately made aware of all the under bonnet tinkering as it catches and settles into a lumpy idle overlaid with a pulsating exhaust note that is full of purpose and fantastically naughty.
Moving off, its the added torque that make its presence felt more than anything else. At lower revs, the M3 GTS feels more muscular than the standard M3 not a lot but enough to make you think the engine changes have been worth the effort.
The acceleration is clearly stronger and not so heavily weighted towards the business end of the rev range, something that provides it with added flexibility and a more determined feel.
The response is something else. BMWs M division has retained individual throttle butterflies for each cylinder and full variable valve timing, endowing the new V8 with sensational pick up. Its not quite as rabid as similarly sized engines boasting a flat crank design, but it is mightily impressive nonetheless. All of which, gives the impression of added speed right throughout the range.
Less mass helps, of course. At 290bhp/tonne, the M3 GTSs power to weight ratio is rather sharp not stunningly sharp but sharp enough to make the standard M3 appear somewhat blunt by way of comparison.
The dual clutch transmission makes light work of the engines added reserves, providing rapid shifts in manual mode without the startling clunk you got with the old sequential manual unit when changing gears at the redline. Its definitely the right choice for the car. A traditional manual would be out of place here.
Overall effect: this hardcore M3 goes faster, feels faster and, most of all, sounds faster than any road going versions of Munichs legendary coupe that have come before it over the past quarter century.
What sets the GTS apart most from the standard M3 from is its sharpness. Everything you ask of the new coupe is carried out with greater immediacy, added response and heightened accuracy.
The steering is heavenly heavier than the standard power assisted hydraulic set-up, but the added effort thats required is more than made up for in precision. Turn-in is instant. Theres no slack as you come off centre, just eager, linear response.
Even at high speeds the M3 GTS remains wonderfully flat and neutral during cornering, and with the DSC (dynamic stability control) switched into M-mode theres rarely any intervention. Arrive too fast into a corner, though, and you find the new BMW will eventually understeer. But with a good deal of commitment and DSC switched off you can drive around it. The limits are so high, though, youd likely never get near them on public roads.
The upgraded brakes are also well up to the job, providing firm and solid retardation. Granted, we didnt run many laps, and those we did were broken up by cool down pass through the pit lane, but the pedal action remained strong and there wasnt any obvious sign of fade.
Should I buy one?
I ache to spend more time with this car. The M3 GTS possesses a singularity of purpose that is utterly intoxicating. At this stage, we cant say what it would be like on the road. Firm, for sure. Although with manually adjustable dampers, the default road setting with which it will be delivered to customers is claimed to offer a good deal more compliance than the race setting we experienced.
But with BMWs M division set to produce no more than 150 examples of the M3 GTS in both left-and right-hand drive, its apparently already too late to lodge an order. Word is each and every one has been sold.
[autocar]
Ok, the pepboys wing really needs to go. It looks like it was just tacked on as an afterthought rather than something done intentionally. It's like they said "hmm we're making this a race car, but it's missing that last little piece that says 'I'm a racecar'....but what could it possibly be?....I know! A hideous spoiler from the local autozone will really up this car's track cred!"
Actually it's not just a thrown on afterthought, it's an adjustable carbon fiber spoiler. Ie. it has function.
Well, it may be functional but it looks like an over sized clit@(stripper)
They could have put a better spoiler on the back. But I'm not that big a fan of BMW's anyways. I like them, but I think they are over rated and over priced.
Well, say what you want, the quality they give you in terms of parts and performance, they did their homework and expect to be paid for it. Buy a dodge, ford, chevy, you won't get anywhere near the amount of of quality in parts or performance. There's a reason why BMW has won engine of the year numerous times in the past few years or have come very close to winning. Overpriced, yes, over-rated, not really.
all I have to say is that BMW must know what there doing....For starters look at the paint color!!!!!!!!
<object width="640" height="385">
<embed src="http://www.youtube.com/v/dCYR7BFUTMk&hl=en_US&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></object>
Consistent lightweight construction, adjustable aerodynamic units, an increase in engine size and output on the V8 high-speed power unit and suspension technology meeting all the requirements of motorsport – all this gives the BMW M3 GTS a top position among high-performance cars built for Clubsport racing.
M3 GTS weighs 1490 kg (3285 lbs), 419 lbs less than the stock M3 coupe’s 3704-lb curb weight.
To optimize the flow of air and adjust the car’s downforce as required, the BMW M3 GTS comes with a race-oriented front air dam and rear wing.
BMW M3 GTS passed all the European street-legal requirements, in contrast with the North American market where regulations around EPA or federal safety standards are higher. Modifying the GTS to make it US-compliant would be a very costly affair because the car lacks airbags, proper DOT seatbelts, proper bumper height and many other things.
thats yummy...giant spoiler, and oh yes to the spicy orange...errr...M - Orange :P
sooo sexy
