I need part numbers for a couple parts.
streetboi
ok so as of right now im rebuilding the transmission and broke some parts along with needing replacements.
i need the seals for the transaxle that go to the differential.
also the plastic trough that runs from the center of the transmission for the 5th and reverse gears. it runs oil to them. i broke this one while i was taking that black cover off.. stupid crappy plastic.
also the rear motor mount is missing the bottom bolt thats in the transmission. (when i replaced them to neoprene i must have not of put it in tight enough) im sure i wont need a part number for this one but i dont think it will hurt if there is one.
i havnt seen you driving around calgary before. i used to work in the SE foothills area. (random i know just saw your from calgary)
ive done it on dirtbike motors.. there isnt a lot of pressure in the low end of the engine ill post pictures tomorrow of the motor sitting in my garage. lol but you wouldnt know anything about that now would you?
I've only built 5 Protege engines and 3 dirtbike engines, so no, I probably wouldn't... Hahahaha!
(lol)
Dang it man. I almost forgot about the engine block ordeal......
Look for the sticky on it under the MSP Section. At the top of the page. Download the links, and your set on part numbers. Or go to OnlineMazdaParts dot com. Great way to get part numbers as well.
