So I'm finally finishing up with all of parts buying and thought I'd throw a few pictures up. I really haven't done much with the car but I'm ready to move toward getting the motor in. I did however strip all of the body filler out of the roof channels; which actually wasn't as bad as I thought it was going to be, did all of it in about 20min. Sadly I found a fair amount of rust, but after seeing the rest of the car and the way the body work was done, I was expecting the worst. The chosen method to fix was surprising though; they stripped most of the paint from the channels, but didn't weld the holes for the roof rack shut, instead just filled it with the body filler. On top of the body filler was a layer of fiberglass, which I can only assume was to try and keep the water out (epic fail). After the layer of fiberglass was more filler (YAY!!!!!!!) Seriously, who hates the roof rack that much? I even managed to pull the right side filler out in one piece, see it against the car...
Below are pictures of what I've collected thus far, you can probably recognize most of it from the pictures, but I'll throw a list near the bottom of the page. Enjoy, let me know what your thoughts are on the direction of the project and if you have any questions/suggestions. I also have a ton of stuff stored in the P5, the wife already isn't very happy my taking over the guest bedroom, but the p5 only holds so much
