MP3Night Turbo Build
Haha,That looks like a good option. were you going to tap into the stock water and coolant places?
Like this:
Oh okay thats what I was going to do from the beginning, but changed my mind and decided to just run it like this.
Is your compressor housing on your turbo tapped? I was going to use this quick tap so my line for my wga isn't so long.
Not too sure...lol I hear that Recirc and relocation of the maf are two good things. (although we wouldnt have to relocate. lol)
you can get those check valves at autozone, i tried to order one also from online mazda parts and they didnt have them in stock. its just a one way check valve.
edit: i did this pipe routing with that cx racing kit that you have
hot side
cold side
is that the one your using? because i have that same one and I don't know if its going to be big enough to fit in the line
yeah its in now. there is an adapter in the line, it changes sizes from a bigger line to a smaller that runs to the IM. just remove the adapter and put the valve
in its place.
