Current Parts list:
Stock msp turbo
Stock msp wastegate
Stock msp radiator
Stock msp AC condenser
Stock msp oil cooler
Stock msp ECU
Stock msp S and J pipes with techline coating(bought from Focus)
Corksport J pipe(will install this if I can find CS S pipe)
Thunder manifold
ETS/CustomMSP SMIC(same thing)
Hard pipes
Injen Intake
Yudkib vacuum block
Vibrant soft mount vac line fitting(for wastegate)
Check valve for purge solenoid(prevent gas tank from seeing boost)
Perma-cool 8" and 12" slim fans
Greddy Type RZ blow off valve with 32mm recirc fittings
AEM analog wideband A/F gauge with white face
Forcefed steering column gauge pod
2.0L valve cover powdercoated black(since I previously did the 1.8L coil conversion)
New coils and wires
BKR6E plugs gapped for .035
All new turbo gaskets
Corksport rear MM inserts
1/2" NPT oil return fitting for windage tray
Parts already installed:
Racingbeat cat-back exhaust
Kartboy exhaust hangers
TWM short shifter
Prosport boost/vac, oil pressure and volts gauges
Tein s-tech springs
Tokico Illumina struts
AXR anti-klunk brackets
Medieval 4pc lightweight pullies
JDM intake cam
Corksport exhaust cam
Stock N/A parts have already been removed. I will take pics as the build progresses...
Stock msp turbo
Stock msp wastegate
Stock msp radiator
Stock msp ECU
Thunder manifold
Hard pipes
Injen Intake
Yudkib vacuum block
New coils and wires
TWM short shifter
Tein s-tech springs
JDM intake cam
