subbed.
My lo-beam HID kit came in the mail today as well as a new battery tie down. (2thumbs)
Changed out the spark plugs today...
Ordered swaybar endlinks because all the bolts are stripped on my currents and i cant replace the bushings because of it. When they come in im firing up the saw..![]()
Which to which?
NGK ZFR7F-11 (What I always use for higher boost...)
I thought the ZF plugs were bad for turbo/higher boost? Should I use ZF plugs on my build running 6-7 psi?
Yes, they are better plugs hands down. You probably only need a 6 heat range plug tho. 5 for n/a, 6 for stock msp setup, and 7 for higher boost applications.
