Can you clarify what this means? We are trying to figure out if the AFC can control fuel in closed loop? Does your statement mean that the AFC controls when the ECU is in closed or open loop? So, when there is boost, the car is running in open loop?
Also, if the AFC does control when the ECU switches from closed to open loop, is there a setting which allows us to modify at what RPM this happens? Or does it occur when pressure is detected on the MAP sensor that is included?
(sorry this is pretty choppy explanation, it's not easy to do this without showing someone, and after the essays I have been doing for school the last few days my eyes hurt and brain is dead lol)
First of all, thank you ken for the explanation, my head was spinning reading through this thread about what people were talking about, and trying to tune closed loop when, like I said below, at 4krpm, in boost, your in open loop already...at least I know you definitely are with the ssafc unless the settings are wrong for some strange reason.
ok so here it is, I would highly recommend you to read this thread, and look through the pages, if you take your time to look through all the pages and just skim for stuff with good information, you will know all you need to know about this thing...
http://www.msprotege.com/forum/showthread.php?t=123620555
ok, now like ken said the SSAFC can tune the car in
open loop only but this does not mean that you can't tune your car when it is not in boost.. when your car is in boost, it is in open loop, when it is not (at least without changing it with the ssafc) it is in closed loop, like said before in closed loop, the ecu takes the readings from the primary O2 sensor..
what I THINK you are asking, is to be able to tune the car below 4k rpm.. which I don't know why anyone thinks it's in closed loop, unless there is something I strange that I don't know about, but below 4k rpm, you can do 2 things,:
1.) you can force your car to go into open loop through the SSAFC (which I will explain in a minute) when it is out of boost, which like ken said, is what people do to tune for larger fuel injectors
2.) or you can just set the settings from you ssafc to start to edit (for lack of better word now) the fuel cells, or fuel injector pulses (add or take fuel from stock ecu map basically) when your car goes into boost, which is what most people do and have the ssafc for..
The ssafc comes with the stock supermap which is set to/or should be set to "over pressure" of 1.1psi in the "Options" then "Engine Output Settings" then just go to, first, the over pressure scroll down tab change the over pressure to over pressure OR over rpm, it is good to do this encase your wga breaks or something and that way the ssafc will take over when it goes above the 5.5k rpm (which the stock ssafc is set to)
but really don't worry about that over pressure/rpm settings right now, just go to the "Over Pressure" text box that says 1.1psi, change that to 0 or .5 or whatever you want the ssafc to take over the ecu fuel levels.. it is set to 1.1 because below that the air fuel ratios at such a low boost doesn't really matter too much.. but some people and myself like to set it a little lower so that the car switches over from closed loop to open loop quickly and can alter the afrs slightly faster (it may not do anything at all, but it's personal preference and in my experience I like it to switch over sooner so that I can try to get the afrs down faster while building boost)
sorry for the long, round about explanation, I'm just trying to not leave out stuff that might help with the understanding of the ssafc and how it works.
-bottom line is the ssafc stock supermap comes preset of over pressure at 1.1 so once you hit 1.1psi in boost, the car switches from closed loop to open loop and the ssafc takes over and adjusts the fuel.
oh and yes, get a wideband.. you won't regret it, and you won't be able to tune without it anyways, or you'll have to pay someone to dyno your car every time you want to alter the map anyways
um.. I think I missed some things but I'll leave this for now
