I recently dyno'd my 03.5 MSP. Mods are FMIC, SRI, ATP wastegate, catless midpipe. I believe my MSP was flashed by the P.O.. I put down 176.2 WHP, which I think is respectable for the stock ecu. My concern is with the AFRs that I got from the runs. I always knew when driving that I would not go WOT until after 4k rpm because it would just run like crap. Well, this chart shows why, it is crazy lean until somewhere around 4k rpm then crazy rich afterwards.
So, now I need to understand better what is going on. Is this just the way the stock msp ecu operates? I'm thinking that I may have a problem somewhere else. It feels like timing is too far advanced (would this cause lean?) beacuse onces it hits the switch over point around 4k rpm, the sound of the engine changes. Also there is a very noticeable increase in power.
What I need to know, is this normal? Is it possibly a problem with metering, o2, vacuum leak, etc?
Also, if this is normal will an SSAFC fix this or do i need the SSFTC (assuming that it is timing which is causing the lean AFRs)?
Thanks guys!!
ps: the chart also shows PSI, any idea why there are so many ripples in the boost? Is my new ATP wastegate bad?
Thanks guys!!
