youngereveryday
I finally made the decision to go ahead & get the Corksport CBE. Excellent decision it was.
I originally intended to also get an ATP downpipe (& still want one), but frankly, I chickened out! I ultimately determined that I'm just too damn "vain", to be seen driving around in a smoking bomb! Damn vanity. Anyways, my installer said he's installed hundreds of aftermarket catbacks, and this is easily the best fitment he has encountered.
One small problem though, there is a leak at the cbe to cat joint; when I put my hand real close to it, you can definitely feel air blowing out (a small leak on the bottom of the flange-flange joint & another at the top). My installer suggested the cat-flange is slightly warped, and the best solution might be adding a second (metal) gasket. A forum member suggested it will likely seal itself, and check it again in a while (?).
I will start by saying this exhaust sounds absolutely HOT!!! There is a slight performance gain, but the real gain is the much improved sound over the oem system.
WOW . . . this made my car WAY more fun to drive.
My new wheels should arrive from Japan any day now . . . my next treat.
cheers.
BTW . . . I was not aware of this at the time of purchase, but fair warning to any other Canuck buying Corksport, you'll pay customs/duty on their stuff, because the country of origin is in Asia (S. Korea I believe).
cheers.
