fatti03msp
Contributor
- 03 MSP & 91 RX-7 & 00 1500
ill sell you my old shell after i take the motor out of it lol
Will the TII intake manifold work with the 6-ports on the N/A motor, or are you just talking about swapping the UIM? Also did that car not already have the 4-piston front brakes and vented rear disks? From the rear wiper it looks to be at least a GXL...im going to be swapping over to the TII intake mani for now, a lil better then the NA S4 intake mani.
but my roommate def. knows what he is talking about.
I also picked up his old chassis today too.
91 rolling chassis.
TII Brakes
TII Hood
Tien Springs
Walboro 255lph
And NO RUST
My chassis is just too far gone and so rusted out, plus its a base 4 lug model so this will be a big upgrade for me.
Gotcha, I think the GXL and TurboII brakes are the same (4-pot fronts and rear vented disks) so it may be a misnomer to say "TurboII brakes". Regarding the intake manifold, the N/A motors have 2 auxilliary ports (called 6-ports) the turbo motors do not (called 4-ports). If you switch completely to a TurboII manifold, both upper (UIM) and lower (LIM) you may end up blocking off the auxilliaries on your 6-port N/A motor. The TurboII UIM may have the TB flange on the opposite side as well. You'll be better off modifying a N/A S5 intake manifold to fit as that is fairly common.the brakes are stock on the chassis i bought, but my fc is the base 4 lug model.
I was just listing what ill be gaining by going to that chassis
as far as the intake mani im pretty sure it still will work, im still a nub to the rotary world so i could easily be wrong.
I'm not sure about the flowing better part, but why do you want the TB on the driver's side? Unless you're ditching the P/S and A/C and relocating the battery there is more space on the passenger's side.the main reason y i want the turbo intake mani setup is for the throttle body to be switched to the other side.
also from what i hear it flows better too.
Nice find on the S5 shell!
-Derrick
I'm listeningWho needs all that stuff? lol and the battery is in the back already
but once what i have up my sleeve done im pretty sure you will like it.
Hold on - are you talking about merging the two ports together (on the irons)? If so, that is widely considered a very bad idea (Mazdatrix has a write-up on it). If you're going to go that route I'd suggest filling the auxilliary ports then start from there (essentially making a 4-port motor out of a 6-port). Just trying to help out.as for the ports.... there stacked on top of each other.
all you have to do is port the opening bigger and your good.
N/A motors are 6-port unless very early 13B. Turbo motors and early 13B/12A were 4-port. Your engine likely has 6 ports, the intake manifold you want to use has 4. Are you just going to hog out the manifold until it opens up over both the main and auxilliary ports?on the intake mani side
as of now i have a 4 port NA motor
Im taking the 6 port Tubro mani and you port it out so its no longer 6 port.
Gotcha. Yeah, that's what a lot of people are doing nowadays with turbo motors being harder to come by (and more expensive). Still slightly different timing but I've seen it work. Good luck!ya i failed bad lol
i do have a 6 port
but you just fill in the ports and port match to run the turbo mani's
but flushed my coolant today and i think my motor is bad.
There is alot of pressure in my cooling system... enough to blow off the hose that goes from my goose neck to my overflow tank
