shane02pro5
25ish_psi
- New Caney TX
The average person doesn't drive a turbo vehicle also but if they did I'll bet 90% would run synthetic
I don't use synthetic because I like to go fast or push my car hard. I use it as a preventative measure against sludge, varnish and shearing. You don't have to be an auto enthusiast or a race car driver to use synthetics. You just have to be an informed consumer.
Royal Purple 10w-30 with and Royal Purple filter.
Uh oh someone's jockin my license plates! lol jk. I use full synthetic usually valvoline 5w-30 but I tried castrol this last time and might stay with it. I also try to use mazda oil filters.
How is the royal purple filters?
I always stuck with K&N because its much easier to take it off for me![]()
Does anyone have oil analysis as proof that using mineral based oil is leading to excessive wear/tear of their engines, or is it simply conjecture?
Where turbos are concerned, the UOA isn't what used as proof that syn is better for that application. It's the teardown of a failed turbo that tells the story. The condition is called 'coking'. When conventional oils are repeatedly subjected to temperatures that are technically out of the range of what they are designed to handle, they begin leaving behind tar-like deposits that eventually block the passages into and out of the bearing races in the turbo. Depending on OCI, driving habits, and the design of the turbo and the engine, it can happen quickly, or over a long period of time. Once the passages reach a certain level of restriction, oil starvation takes hold and the turbo is done for. Synthetic oils won't coke, making them more desirable for use in high heat conditions.
People that drive turbocharged cars who are in the habit of driving hard, or driving long distances at high speeds and then shutting the engine off without a few minutes if idling are begging for trouble using conventional oil. These people should either use a turbo timer or switch to a high quality syn to avoid coking.
Not sure what's meant by 'distance from exaust housing', but in the case of the MS6, isn't the turbo an integral part of the exaust manifold? That would put it pretty close to the heat, so why would I want to change my oil every 2000 miles to avoid a condtion that synthetic oil could eliminate?
If you suspect you have a sludge issue, removing the valve cover is probably the best way to see how bad it is.
