Aggressive fitment anyone?!
good point lol
and no i couldnt test fit them, i guess i could buy one and see how that fits before/if i buy any more
there only 87 bucks
Thats not horrible, I would buy one just to try. Oh, and you'll have a s*** load of inner room for camber since its only 8" wide and you gotta remember, Hung didn't adjust the stance at all, he just through it on with his settings for his wheels.
ok just found the same rim, 17x8 4.5" backspacing
anybody know how to convert backspacing to offset in mm?
edit: nvm, found a little chart online
so im not going to get the rims, i forgot i dont have full coilovers and i cant go as low as i wanted on the 16's anyways
I've been messing with my height and camber in the rear all morning trying to get it just right and I'm exactly -2 degrees and you with a 35mm difference 1.375" would poke 1" past the outer edge of the fender and pretty much require stock ride height :(
in to mm conversion is pretty much exactly what you'd think. just take wheel width minus backspace, and that will give you the positive offset amount. so in your case whatever to 1/2" converts to. roughly +14mm if memory serves.
I think that's about a 9mm offset my 8" is 9.7"/2-4.5"=9mm+/- offset from center.
i have a question: can any tire be stretched? i have general tires(205/45/16) and im wondering if i could put them on a 8 inch width rim.
well according to the chart i looked at online, they said a 8" wide wheel with 4.5" backspacing was 0 offset
so idk, either way im not getting them lol
and yea you can put those 205/45's on a 8"
