Hello all,
what we have here is a 52mm and 60mm defrost vent pod. and the Turbosmart dual port bpv. EVERYTHING SOLD
Now for the details.
I bought both of these vent pods in anticipation of using one or the other then just selling the one i dont use. well, i cant seem to make up my mind and decided i have enough gauges and could use the money for something else.
These pop right in. literally. you just tug out the stock piece and pop this in. matches the oem color perfect. this would be perfect for you if your lookin to put in a boost gauge. i was considering even using one for an Aeroforce gauge. but since i have an ap, more gauges is overkill for me.
$$70$$ shipped for either one!!!
52mm!!SOLD!!
60mm!!SOLD!!
And finally this blue and silver Turbosmart dual port bpv.
This valve is adjustable and comes with a gasket, block off plug for full recirculation, and the horn for dual port set up. the valve is in great shape and bolts right in to the stock mount and stock recirc hose.
I've had this valve for well over a year now, however i've had other valves during that time(forge,hks) so it has'nt spent the whole time on the car. i would guess i could have as lil as 5k on it, to as high as 10k.
The sound in dual port is loud. very loud. and you can hear it quite often even with light throttle release. the sound is a very sharp, unmuted sound. i'd best describe it as whip crack.
In recirc, the sound is more muted. though it is louder than stock. its a very percussive, industrial blast of air type of sound.
There is some backfiring with the dual port set up. it takes time to adjust the valve, but you can dial it out and keep the backfires to a minimum. it may be one in every 30 shifts but still backfires none the less.
in full recirc it works like stock. no backfires and holds boost like a champ.
for me though, i'm over it. and like the pods, i could use the money to buy something more useful for mistersix.
$$225$$ shipped!!SOLD!!
i accept paypal only at this time. lancenmeem@gmail.com
shipping is only to the 48 states. outside of those pm me for a quote.
my prices are firm and fair. so please dont low ball an offer. i'm a straight shooter when it comes doin business, and expect the same in return.
thanks for lookin
Nik
52mm!!SOLD!!
60mm!!SOLD!!
thanks for lookin
Nik
