///M Compact
It's RWD which means you're pretty much F'ed in the winter (if you live anywhere north of the Mason-Dixon line).
Nah, you just need some decent winter rubber.
i was in my MS3 and drove by a Jeep SRT8 and thought to myself...boy...i would love to have that vehicle when I produce offspring! ill make sure im in my car whenever i have another urge to like a different car...problem solved
They are fun..but not for long. The trips to the gas station get REAL old REAL fast. And it's never cheap. I'd rather get an EcoBoost Flex when we have kids.
Just pulled IC off again to get to the back of the motor so I can check all my exhaust bolts because I think my leak is on that side now..... going to install ITV22's at the same time.
lol i dont know if its cuz of autox or sheer bad luck but yur s*** is always leaking or loose or s**** hitting you. your engine is in pieces more than its running it seems like!...do you walk under a ladder and break a mirror before school everyday???
The stocker TIP is extremely restrictive.Got the PG TIP installed last night. Now I should probably note that I did not remove the battery tray. Stupid move. What a mufucka that thing was to get in. I look like I got into a fight with tiger. Definitely put some blood, sweat and tears into that thing last night.
As for first impressions? Intake is definitely louder, and turbo seems to spool faster. Don't notice much more pull, but I'm taking it easy for the most part until the ecu gets used to it. Also can't believe the design of the stocker. LOL. WTF?
The TIP is just a flow part, not a HP part. More flow, more consistent boost, and faster spool.
An intake is also a flow part... and it makes HP.
An exhaust is also a flow part... and it makes HP.
Getting a valve job increases flow... and it makes HP.
Great, you've proven me wrong.
Now... TIP does nothing for HP. It reduces restriction on the intake side, but does NOT gain HP whatsoever. Ask COBB, Corksport, and PG. They will all tell you the same exact thing. Infact, i'll save you the trouble:
http://www.corksport.com/blog/mzr-turbo-inlets-comparing-apples-to-apples/
You need to relax
Just, no point in being technical over a TIP - it does increase flow, but doesn't result in any HP. HP is all generated on this car based on load and boost targets. Reducing overall load/restriction helps the turbo generate power sooner, but not any increased horsepower. Tis all I was saying.
You're joking right? Because...1st gear is good for nothing but ripping the tires apart.
