Ride is good. My girl says it's not too bad and on the first day home she fell asleep in the car and didn't complain about the ride. I have the fronts set at 7 and rears at 15.
and do you have the new bcs?
SU boost tubes showed up today so I can put my car back together! Also AWR adjustable rear end links shipped today!
Ignorant question..why the need for adjustable rear end links?
But for stock suspension, it isn't necessary right?
I'd imagine, with adjustable links, you could lengthen the links so there is no tension on the bar while the car is on the ground, this way it won't prematurely load the suspension right?
Do these adjustable links have the right thread diameter? I've read reviews on these links where people complain about having to buy spacers to properly fit the mounting holes on the RSB.
Well you're only preloading the bar if the two corners that are linked to it at are different static suspension "heights." When you corner weight a car, you use the coilver height adjusters to set the corner weights, which can lead to having one side slightly "higher" or "lower" than the other side. This puts tension on the swaybar, and ajustable links are needed to resolve that tension by lengthening or shortening the links on one side or the other to compensate.
Does that make sense the way I explained it?
put 94 octane fuel instead of 91
Sort've.
I need to start learning this stuff more so I can understand it.
So would you recommend adjustable end links for a rsb? I know it's been heavily recommended for FSB's.
	This is as of Saturday... but better late than never! Picked up some new shoes, complete with curious george:
Got them locally for a steal. Going on probably early April.
Also snagged a full 7 piece set of that PG 'GTSPEC' style chassis bracing. Will be going on whenever I get a free moment and the motivation.
