I don't know if your gauge is like mine (Autometer Digital), but with mine you have to turn the key to on for a second, then turn it all the way to start. During that brief pause the gauge recalibrates itself. If I don't pause in the on position prior to starting, the gauges don't zero properly and the readings are therefore not accurate. You might try it with yours or check the documentation that came with the gauge.
need more info... this is in the R4 software i take it? when opening customer? did you download the map from this thread?
I would suggest a 440cc map, or a FMIC map.
These are all just starting maps anyway. Custom tune is best.
