Aggressive fitment anyone?!
lol seriously, hellapoke. I think if he saw a 25mm spacer he'd change his mind haha.
Actually, looking at his ava, hes gonna need to stretch tires or get some mad camber to even do 15mm
Someone do some diamond racing wheels. Issue I see is the weight of the wheels, 16's weigh around 30lbs. Then again this styl really is about performance eh
That pic is on 215/45's. Here's the best way to describe how sunk I am.
BTW, I have H&R camber bolts and all 4 fenders are rolled....
Unless you are getting smaller tires then you won't be able to get more then a 10mm behind those wheels
30freakinpound16's...you guys are doing it all wrong :(
they that'd be my major problem with those.
http://i82.photobucket.com/albums/j256/jdmvti/myblock.jpg[/IMG
[IMG]http://i82.photobucket.com/albums/j256/jdmvti/beach073.jpg[/IMG[/QUOTE]
problem is they dont offer a size that we could use, someone said the 16x8 only come in +12 offset and i really dont want to do a 16x7
the 17x8's weigh a colossal 34 pounds but i guess those would be sweet as hell
i dont think the guy was right, i just checked the site and it says anywhere from 1.5" to 5" backspacing....idk ill have to call i guess
Yeah, you have to call to get an real info cause my guy said +12 too and they don't have all the sizes the offer on the site so it doesn't match.
I'd get some 17x8 +38 real ******* quick if they make em. If you call, make sure to ask if they have that size for me ;)
so when you add that inch to the width( i have a 7 inch wide rim now) how does that effect the offset? cuz i was thinkin gettin the 17x8 +30, but i dont how much poke that is really.
Tried on my friend's BBB RS 17x9 +14!!! Front camber. -1 camber (unadjusted)
Rear camber is fully cambered. -3 camber
Very light rub in the rear.
Better pics tommorrow!
Before fender rolling... expensive 225's for traction up front and only 215's would fit in the rear. Had a blow out in the rear replaced it while I was broke with an inexpensive tire then another worn rear had a bubble on the inside sidewall noticed while rolling fenders.
Are you running spacers with this set up?
