03.5 fog lamps
how did you install yours , im still havnig to redo mine :/ its hard to do things without the correct tools , i also i used to fuse box , theres a unused spot where the relays are , i used a female crimp to hook it on there as my 12v source
I ran the 12v wire through firewall and tapped into hot wire on ignition switch. worked like a charm! they are super bright!
I forgot what size foglight fits nice and snug inside the 03.5 lip without poping
out... does anyone know or can you point me to the correct thread etc.?
shop just installed lip and I have H3 HIDs that I hope can fit into a smaller foglight.
I got the same fogs. I used the back part of the delete (chopped abit) and just got some thin flexable black plastic. cut to fit snuggly in the bumper hole and just cut out the middle enough so the lights back fits threw. thought it would be ghetto but actually turned out to look like a nice finished solution made from stuff I had laying around
i got the same fogs. I used the back part of the delete (chopped abit) and just got some thin flexable black plastic. Cut to fit snuggly in the bumper hole and just cut out the middle enough so the lights back fits threw. Thought it would be ghetto but actually turned out to look like a nice finished solution made from stuff i had laying around
pob :)
nice... I was at the shop looking at options that's the exact route I am going to take... when you get a chance try to post a pic.
