AFC-SplitSecond PSC1 Map Library
yeah, know that just making sure. I guess I'll compare the superstock to fmic map and go from there once I actually start.
so around 10-11 wont blow the engine right? Ill see if i can tweek it a bit. I want to be around 11s.
you're more than safe.
well i install wideband yesterday and at idle it reads from 14.7 to 15.3 but what your saying while boosting it should be reading lower?
idle is a whole different ballgame. under boost is when the SSAFC is activated (on the superstock map its about 2psi that it activates, but its adjustable). I'm talking about under boost, which is when the tune really matters.
ok i think i get it a bit now so when while i have the supermap install and i am under boost i should see readings around that area so anything higher than 12.0 will cause me to go BOOM ? sorry ask so many question i'm new at this tuning thing also
Alright well I'm tired of waiting for my friend to help me tune this thing. I want to try and learn this myself, so what is the best way to get started? I have the stock super map loaded already.
-Do I need to have the datalogging wires attached to do it myself? Or is that just a nifty feature to have? I plan on installing them ASAP but I don't have a soldering gun.
-Does anybody know about how much the Air/Fuel mixture will change if I alter a cell value by .1? Just trying to get a feel for how sensitive the program is.
-Lastly, do I just start plugging away at areas in the powerband that appear to be super rich?
Thanks guys.
final question i just need to know if im on the right path my mod are listed below. Just need to know if a good idea to run Supermap until i can get a good tune? Also does it come already with the afc or do i have to get it from here?
Mod list
Turbolifes FMIC & Boostsciences Rdv
Corksport 80mm exhaust
Injen CAI
Boost gauge & AEM wideband
