Aggressive fitment anyone?!
At the upgright or via the upper plates?
Not sure the correct terminology.
The two bolt holes that attached the hub to the strut are more slotted as opposed to a hole. I picture may make more sense then my poor description.
Don't be to ruff with the finish on the rims. I would suggest washing them with the soap you use on your car and nothing harsher. Little to thick of a sidewall for me but it looks good.
can you tell us whats your camber set up
my first set looks just like the WORK Equip, but they are made by a company in Japan called More CW-33. I just sold that set couple days ago too :(
spec is 17x8 35mm offset, stretched on 205-40-17 tires
second set are Advan SA3R.
Ill be holding onto these for awhile.
spec is 16x7 25mm offset, with 195-50-16 tires.
I used to be in the Euro scene, where fitment was everything!
thats where I learned about wheel fitment.......
now that I think back. I should have poked my wheel out a bit more on my A4, but I was too worried about "rubbing"
now I just dont mind it. lol
http://www.mazdas247.com/forum/showthread.php?t=123735900
Front -2.0
Rear -1.6
Zack has the beefier setup. RPF1's on 235's with a bit higher offset.
Setup looks sooooo good. I can't wait to put beefier tires on mine now. I gotta run spacers to keep up with you guys. I guess et42 just isn't enough anymore.
looks good drew - fronts look spot on - whats up with the rear roll? looks a little mangled?
question
thread jack,, so i speant over a hour reading all 80 ish posts, all of them, and i still have a question. i am running the stock RH wheels and i am loking at getting spacers to sit flush and i know i need longer studs. what would be the best size spacers for my msp that would look fire!!?? i want to sit wide. but not sticking out, and i will need to adjust camber too, i know. and new wheels are in the future build plans, by the way. thanks everyone
well the stock offset is like +50-ish so you could use anywhere from a 15-25mm spacer then u would have +35 which would be pretty flush or +25 which might poke out a little depending on tire and camber
RHs are +55 :(
I have a 30mm would be great looking but you're talking about a 25mm spacer. lol
i had a 10mm on my +48 rims and it was just a hair below flush
so thinkin about it, i would go 15mm, not any higher
make sure you get some good hubcentric spacers though
edit: holy s*** lol thats a high offset, +15 would still look alot better then stock
Anything would look better than stock. lol. I have 10mm right now but I was running +32 on my 5zigens and it was flush.
Also, to compare two rims, they gotta be the same size or else the offset it different, just in case you're running 17x7.5
I run during the summer OZ Ultraleggeras which are 7 inch rims at +38 and its pretty much as flush as I think you can get with 7 inch rims.
