updated 18-55IS? wait.. you're shooting the non-IS? or there is a revision of the IS version?
Get a 50d instead!
Your 18-55 is not worth 100 bux I don't think. With IS , maybe.
Flyin' - do it up man. But it depends as well...how big the sensor size is and how many MP it has. The more MP squeezed into a tiny sensor...the worst it is for losing detail...and low light photos. I'd say 8MP woulda been really good for the XTi instead of 10.
LOL we have a canon vs. nikon debate raging in the WI section.
I love it. even though I was pwnt in it.
sell the body and lens. buy the t2i body only, and upgrade to a better lens.
Prime lens for shooting. 50mm or the 85mm. It's light enough to not need IS. Plus get a Glidecam.![]()
Okay that does answer a lot. I have iPhoto too and although you can adjust a lot in it, its not nearly as fine-tuned as Photoshop is. The only two places you should need to go for color and light levels in there (assuming your photo is exposed correctly in the first place) is:
Enhance > Adjust Lighting > Levels: I usually darken the lower slider slightly, and increase my mid-tones a bit.
Enhance > Adjust Color > Remove Color Cast: This will automatically adjust the color balance of the photo in relation to where you click the dropplet. Pick a part of the photo that is in direct light and is either pure white or black and Photoshop will do the rest.
I once read, as well that you shouldn't have the IS turned on when you have the camera on a tripod for a long exposure, since the stabilizer will be trying to adjust constantly throughout the exposure... I've found that to be true in a couple of my shots and turn it off whenever it goes on the tripod. That might explain some of the blurriness.
I learned photoshop through trial and error, reading up on it via various sites, asking for help, and even through some classes I took back in school. I'm sure there's even more I could do with it, but for now I am happy with my level of expertise with it.
This is what I think I should do. Glidecam would be badass too!
I need a good wide lens to compliment my 55-250mm, but need a prime as well. Ideally I would want the 50mm f/1.4 and probably the new Canon EF-S 15-85mm f/3.5 IS to compliment the long lens and the prime...
idk if its because I'm on version 4, or because I'm on a mac... but this was NO help for me...
edit: not NO help... it pointed me where I need to go, so thank you. but the way I have to do it is nothing like your steps. so, the results of your help:
a 50mm prime is great, on a full frame sensor. with the 1.6x crop factor of the rebel sensors, i'd definitely recommend a 30mm prime. that will put you right near the equivalent of a 50mm on a full frame. i have the sigma 30mm f1.4 EX DC HSM, and love it. my canon 50mm never gets used anymore.
Is the T2i a full-frame or a crop sensor? I'm definitely going to replace my Rebel with it within the next few months, so I'm going to be looking at lenses for that rather than my XTi...
Seriously? I thought you read your own link that you posted. Plus you said the sensor was the same size as the 7D..which is a 1.6x LOL.
And Jon might be right...35mm prime would be a good option.
