speed3chris
 - 09MS3
There's days where I fill my tank with 92 octane, and on a full tank trip reads 390+ miles, and I can get every bit of 280-300 out of the car.
However, shell nitrogen enriched 93oct + octane boost... lets just say the fun is short lived.
Ive found, personally, the best way to drive this car is to remain in a half throttle state, shifting between 3800-4200. yes, the rpms are high, and the turbo is pulling, but that is the whole idea. less throttle is less fuel injected into the engine, while letting the turbo itself pull the weight of the car smoothly. This also seems to be the best shifting point of these cars as well, at least in mine. 38-42 is a perfectly smooth shift transfer and clutch engagement.
Remember, the engine contained under the MS3 hood is a performance engine. You can rag on it all you want, flat-foot shift it, speed shift it, smack rev-limiter all day, as long as you keep fluids in check this engine will hold. (Royal Purple is your friend)
I bought my personal True Red 09ms3 in march, ive put 35000miles on it since(dont ask, alot of road trips lol). at least 25000 are pure ream, the car still runs BEAUTIFULLY.
Low RPMs are bad on this particular engine. Its designed for higher RPM where the pull is much easier and smoother. next time you drive your ms3, go 1/3 to 1/2 throttle all the way up to around 5500, and im sure you'll notice 3000+ rpms is where the engine is actually running easier.
Dont believe me, try it
Christopher Lane
Louisville, Ky 40214
19years old, mechanic since 15, driving since 12.
Young, inexperienced, but I know my car <3
Christopher Lane
